- Sep 30, 2005
- 779
- 0
- 71
Intro:
Hi guys, been a generation or so since i have done any OCing (last time was with a load of AMD s939 CPUs), had an e4500 and didnt bother to OC it... but now i have recently swapped over to an e8200 and feel it would be rude not to get the most out of it!
The Situation:
My system is as follows:
e8200 (stock = 8x333 @ 2.66) with Artic Cooling Freezer 7
Abit IP35
2x2gig Corsair DDR2 800mhz, 5-5-5-18 @ 1.8v
Corsair hx500w PSU
9600gt
Antec 900 - fans on medium.
Vista Ultimate x64
Am using Core Temp to monitor CPU temps, CPUZ, to check cpu and RAM timings and Prime95 x64 to stress test.
I have read the stickies and searched this forum aswell as others but i seem to have trouble getting past 380 FSB :S
Basically i can go straight upto 8x380 = 3040 on the CPU, and only require to notch the VCORE up one to 1.2450. This was 16hrs Prime95 stable running the RAM @ 1:1 so its slightly under-clocked (not above 64c max load CoreTemp is higher than Speedfan and my room is HOT right now)
Infact every single voltage except for VCORE has been manually set to the lowest possible:
vcore = 1.2450
ddr = 1.8v
cpu vtt = 1.2v
s. bridge = 1.5v
n. bridge = 1.25v
cpu gtlref = 63%
EIST is disabled and so is C1E.
The 'Fun' Part:
OK so it was all going nicely, got upto 380fsb with only 1 tiny bump up of VCORE and the system is nice and stable and still cool. Soo i tried for 400, this failed to post, tried 390 and i can post but not boot into windows, 385 enters windows but fails Prime95 really fast... soo i decided to try upping to VCORE 1st... this had no effect even right upto about 1.35 / 1.4v.
So, i thought it must be a MB issue and to keep CPU out of the equation i lowered to multi down to 7 - keeping voltage the same.
However, even if i raise both the south bridge and north bridge settings i still cant get stable for anything over 380FSB... have tried with the northbridge upto 1.37v (when its stable @ 1.25 for 380fsb) and still the same :S
Basically i seem to have hit a brick wall at 380fsb regardless of wether i raise all the voltages or not... i figure its one of two things, either i am missing something totally simple or this is the limit for my hardware (which would seem to be tough luck as the mb should be good for almost 450fsb i thought).
Anways - sorry for the long explnation - jsut wanted to fill in as much info as possible so the rest of you can spot what mistakes i am making!
Thanks in advance.
The Situation:
Abit IP35
Corsair hx500w PSU
9600gt
Vista Ultimate x64
vcore = 1.2450
ddr = 1.8v
cpu vtt = 1.2v
s. bridge = 1.5v
n. bridge = 1.25v
cpu gtlref = 63%
The 'Fun' Part:
Thanks in advance.
