Help, images often don't load on website
reicherb
I'm running the Netscape enterprise web server on a Netware 5.1 Server. For some reason, some machines load the images when they access the webserver and some don't. The machines are identical, and I get the same problem internally and externally. I am assuming it's a server issue.
Any ideas?
Here is the site.
Thanks.
have you looked at the code?
i went to your page and looked at the source. i, as an internet user not logged into you novell server, cannot access "file://///cus1/users/2002/csoukup/Favorites". because my computer doesn't know where that is.
you image source path should be in the form of "http://www.chesaning.k12.mi.us/test/imagesfolder/image.jpg" or "imagesfolder/image.jpg".
just my $.02
Thanks for pointing out of the obvious. I thought I explained that to my web developer but I guess it's a more complicated concept that I thought. I didn't even consider that as the problem since some people could get it to work.
I guess that also explains why it works for a few people. Myself and a few others have access to that directory while others don't.
Thanks for your help.
