Hey AT'ers! I need some help...
I had my yamaha htr-5790 set up in our old house to a regular TV...and it worked great through the cable receiver (tv didn't have audio out).
Now, I want to hook up my vizio 42 inch plasma w/ analog audio out to the receiver. I have:
Vizio 42 inch plasma HD w/ audio out
Yamaha HTR-5790 receiver w/7 speakers (all set up and working)
Comcast HD cable box
-HD wires going from my vizio to the back of the hd cable box
-AV wires going from the audio out in the vizio to the "Cable" setting in the back of the yamaha receiver.
PROBLEMS:
Back at my old house, you could hear the speakers at about -30 decibles...which was great. Now, you can't really hear anything until about 0, and when it's maxed around 17db, it's not loud enough and the speakers are fuzzy.....and these things used to be LOUD...so I know it can kick out the sound. The speakers all have monster cables...
What do you think the problem is? Do I have to "reset" the receiver or do I have the wires hooked up wrong?
Thanks!!
uppie1414 on AIM
PROBLEMS:
Thanks!!
uppie1414 on AIM
