ok my set up is below, with the exception of a 200Gb seagate IDE hdd which im useing at the moment with the problems im haveing!
Am i doing anything wrong? im new to the 64 only rally played with xp chips in the past!
I can NOT get my system to run stable at anything above 215 FSB, settings are:
Max Mem clocks - tryed 166 - 200 - auto
High Performance - manual
Aggressive timings - disabled
Dynamic Overclock - disabled
Spread Spectrum - disabled
HT Frequency- 4x
Cool n Quiet - disabled
Adjust CPU Ratio - Startup also tryed 9x
Adjust FSB Frequency - only get upto 215 stable
Adjust AGP Frequency - 66
CPU Voltage - Default
Memory Voltage - Default and also tryed 2.7
AGP Voltage - default
Forgot to mention ram is in green 1 and purple 1 as its double sided, i think thats right ????? or could this be my problem...
This is really peeeing me off
my CPU temp is showing @ 28C to 32C
Any suggestions would be more then welcome!! cheers guys...
HT Frequency- 4x
