2 questions:
(1) What is the header type in the picture at the bottom of this post?
(2) Do you think a standard 1 x 5 internal male plug would properly fit in the header in the picture? The pins seems shorter than normal and possibly closer together but perhaps someone with experience with this header can comment.
I disassembled the Microsoft MCE Infrared Receiver (IR) that comes with the MCE Remote and have moved the circuit board inside my htpc. I would like to use an short internal USB cable (rather than snaking the standard USB cable to the outside) to connect it to the motherboard but am baffled by the type of header used on the circuit board.
I have been unable to identify the header. It is clearly not a standard USB header. I have seen the style of header/cable on a fan controller (single header to multiple 3-pin fan headers). That being said, I'm not sure I'll be able to find a preassembled cable to fit this standard in any event.
If all else fails, I'll simply use an internal (female) to external (female) USB cable (Type A female to a 1x5 female) such as the cable at http://www.frontx.com/pro/c532_012.html . The only downside being the substantial mass of extra cable in the case.
The header and plug:
Thanks for your help.
Other search terms for future users: home theater windows media center edition remote adapter receptacle proprietary
