- Nov 10, 2014
- 156
- 1
- 0
Good afternoon Anandtech, a forum I'm aware is known for its professionals and experienced enthusiasts!
I registered here at this pro-community just to ask this particular question:
Is it safe to run my i5-760 higher than 1.4V at idle? (Perhaps Vcore at 1.45V? So at load, Vcore will be 1.4V.)
I understand Intel recommends max voltage of 1.4V for the i5-760. However the problem I'm having is Vdroop: under load my Vcore is only 1.344V (1.4V at idle) and that is not enough to maintain stability at 4.1Ghz. I'm almost certain I can gain stability if I up to voltage so at load it will be 1.4V. Maybe I can even push 4.2Ghz.
*I do not have Load Line Calibration or VTT adjustments on my motherboard, so that's not an option (unless I can flash custom bios to enable LLC and/or VTT? Is it a software limitation or a hardware limitation?)
Are there any instances where people fried their 1st Gen i5 CPU by running higher than 1.4V Vcore?
I have not tried it yet as I don't want to burn my CPU, so I'm asking Anandtech pros and experienced enthusiasts alike what I should do.
Additional Info:
Motherboard: MSI P55-CD53
- C-State & C1E disabled
- PLL @ 1.81V
- PCH @ 1.05V
- CPU Amplitude Control @ 1000mV
CPU: i5-760 currently @ 4048Mhz with 1.344V at load, 1.4V at idle
- 184 Blk X 22 Multiplier (Blk @ 185 crashes Prime95 at current voltage settings, trying to get Blk @ 186)
- Max core temp at Prime95 load: 70C
- Average core temp at Prime95 load: 68.25C
Cooler: Hyper 212+ in Push/Pull w/ NT-H1 compound
GPU: EVGA GTX 780 ACX @ 1202Mhz Core/3251Mhz VRAM @ 1.21V
Power Supply: PC Power & Cooling Silencer MkII 750W Silver Certified
RAM: 4+4Gb Patriot Xtreme 1.65V 1866 & 4+4Gb Kingston HyperX 1.5V 1866 both at 9-11-9-27 timing & 1.5V
- Separate question: can the two channels be timed differently and still be stable/faster? The HyperX is rated for a lower timing but I matched it with the Patriot timings for safety)
Any help would be greatly appreciated! Thanks
Additional Info:
- PLL @ 1.81V
- PCH @ 1.05V
