help == I was running Vista and I replaced system board
LongTimePCUser
472
I can't book into Vista now.
I thought that I would be able to do a Vista repair using the cd but it doesn't work.
What is the best practices approach to fixing Vista after replacing the system board?
The new system is a core 2 duo (e6420) on a Gigabyte 965P DS3.
2 GB ram. MSI 8600 gts.
It was a vista upgrade ove Windows XP. I called Microsoft. They said I should do a reinstall and that I had to install Windows XP first.
Is there a better way?
Shawn
32,236
53
You can't change the motherboard with a different one and expect windows to still work. You have to reinstall.
LongTimePCUser
472
In Windowx XP you could do a "repair" installation from the Windows CD. I tried in Vista but it didn't work.
