Help! I want to oc my Cel 600 to whatever the max safe...
bacillus
14,517
why not just see if it'll boot with 100fsb as a starter & slightly more voltage than default! you need good cooling if that o/clock is going to be stable.
remember if you're going to try to use 100FSB, ensure that
AGP:CPU bus is 2:3 & not 1:1
best of luck. :)
Wuming
1,030
i am running my C600 @ 900, and it has been smooth and fine! yup, use 2/3 for the AGP divider and 1/3 for the PCI divider.
if you have luck getting it up past 900 please tell me!
Spongo
1,862
What kind of cooling are you using? Also, dumb question, but you got it set at 100 fsb, right?
Jwyatt
1,961
Using a g orb on mine. 600@945 105fsb thats at 1.8v. Smooth sailing. MB is P3V4X.
Good Luck
