wittangamo
- Sep 22, 2007
- 83
- 0
- 0
The basic mistake has been covered already. The OP needed to reset the memory divider from 1:1.5 (266x1.5=400, or DDR 800. When he booted at 333, it went to DDR 1000, and he likely also neglected to bump the memory voltage from the default 1.8 to the spec for those sticks, which is I believe 2.2 v.
It's no surprise the system wouldn't boot. What is surprising is some of the replies he got.
In this case, the 333 fsb was fine and there was no need to raise the vcore. The memory divider should have been 1:1.20 for DDR 800 and the memory voltage should have been set to 2.2. That would have gotten him over the hump.
I do agree with those who suggested he read some OC guides, and the Abit forum link is also a good place to go. RTFM would have revealed the CMOS reset switch built into the IP35 Pro for just such situations.
I can't tell you how many times I've overclocked a system until it won't boot. There's always a moment of panic when you think you've broken you expensive new toy, but there's almost always a way to turn back the clock and get it running again unless you do something incredibly stupid like running without a cooler or cranking the voltage WAY out of spec.
Taking it slow is good advice. But let's remember we all made mistakes and this forum is here to share lessons learned.
