Something just went horribly wrong. I don't know if it was a virus, but here goes.
Stable W2k machine 9 months old, xp 1800+, 512mb DDR, Soyo Dragon Plus, Maxtor d740 40Gb 7200, One HD installed, no RAID, using NTFS. I was installing Roxio CD Creator 5 basic, then installed CD Creator 5 Platinum over it once I found the disk. My CDRW is too new for the ECDC 5 Platinum, so I DLed the update from Roxio. Would not install, saying something like NO compatible product found. I shutdown cold and restarted; still the update installer would not recognize the 5 plat. installation. So I uninstalled the 5 basic, then uninstalled the 5 platinum, and restarted warm to clear decks and start over with the 5 plat. install.
When restarting, I get POST, W2k startup screen with progress bar, then BLUE SCREEN:
"STOP: 0x0000007B ... blah, blah
INACCESSIBLE_BOOT_DEVICE
If this is the first time you've seen this Stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check for viruses on your comjputer. Remove any newly installed HD or HD Controllers.
Check your hard drive to make sure it is properly configured and terminated.
Run CHKDSK /F to check for HD corruption, and then restart your computer."
I had a McAfee Emergency Boot disk which I used. It scanned the C drive using the definitions on the diskette and found no viruses. HOWEVER, MORE TROUBLING, it reported two MBRs on the C drive and NO OTHER FILES!
Am I dead? Who has seen this before? What should I do to investigate? I have McAfee Internet Security 4.0, Norton Systemworks 2002 Professional, and Norton Internet Security 2002 sitting here on CD. And I have the original W2k install CD as well as my WinXP Pro on CD.
I am afraid to do anything else to it until I hear from you guys. Help, please.🙁:Q
these steps:
