Help! I think my BP6 just died on me...
AndrewR
I ran into a problem the other day, and I'm looking for confirmation of my rather unfortunate suspicions. I had a Celeron 366 that for many months sat idle as I was not using my BP6 with an SMP-capable OS.
I finally installed it on my other computer (on a Soyo board), and it ran perfectly stable and cool at 550 at 2.0v. I subsequently acquired a Cel2 533 so I pulled the 366 out of the Soyo and laid it aside.
When I decided to put that 366 into my BP6 in place of the one currently in there (it ran fine at 2.2v but did not like my new power supply so was running at default speed), the first Celeron seemed fine and stable. After verifying that everything was fine (ran at 36 degrees C at 2.0v), I used it for a week or so.
Suddenly, Motherboard Monitor reported the temperature as 56 degrees C!! I thought that perhaps the Alpha on it had come loose so I shut it down and checked it, reseating it (didn't appear to have any problems). However, when I restarted and went into the BIOS, it locked up after about 30 seconds. Temperature reading said about 30 degrees C before it did so.
I thought this was strange so I restarted and set the processor to 366. Same thing at almost EXACTLY the same time after I waited about a minute or so (restarted again for 366). If I try to reset immediately, it doesn't post, and the monitor light is amber.
I tried it with a different HSF and in the other socket -- no change. Is my Celery cooked? What in the world could have caused that sudden change? I'm baffled.
AndrewR
Ok, some more testing information:
I tried to reinstall my other working Celeron 366 and run it at default voltage but received the same error. I stuck my head in the case to see if I could hear the problem, to see what it was doing on startup, and I noticed that the fan wasn't spinning. Hmm. I switched the fan connector, and the Alpha fan was spinning. However, the board won't even post now! No beeps -- nothing.
Is the board dead???
cobain
I've had a few BP6's die on me it seems to be related to the fan headers, as they blow and then fans dont work. So jump in voltage and the motherboards monitor reports one of the voltages well out of spec think 2 Volts instead of 5 Volts. The board then wouldn't start with my DDR but would with a V3 but fail loading windows
AndrewR
Thanks for the response -- I'll send this for an RMA tomorrow. I'm down to one computer again, and it's annoying since my wife and I have to share. :D
