Help! I think I screwed up Audio! (Creative Audigy)
Ender
1,694
My friend was telling me to try some things out to allow him to listen to what I listen over the internet so I was fiddling with the Playback and Recording the volume center (Options>Properties) and now I can't get back to my original default settings and the mic seems to be messed up now!
Can someone tell me the default configuration for Playback and Record using the Soundblast Audigy card in the volume control?
Thanks!
chizow
9,537
I don't have the Audigy, but in my Audigy 2's surround mixer there's a big white radio button that says "Default" that allows me to reset default settings.
Chiz
Ender
1,694
How do you get to the surround mixer? All I have is a recording program and Volume Control...
chizow
9,537
Its just a .dll that comes with the install disk along with EAX control panel, speaker settings etc. They just replace and add a few pieces of Audigy specific functionality to the standard Windows .dll's that it looks like you are using. I'm pretty sure Creative has gone to software/patch updates instead of full software downloads, so I'm not sure if you can get it from Creative's site anymore. That's where I'd look though, otherwise you're gonna need the install CD or borrow/copy one from a friend.
Chiz
