help i reformatted and now im lost
cgper
9
hi im a complet computer noob.
i just reformatted my computer and when trying to get on the internet i check the conncetions and there is only on on there and its the 1394 one whatever that means.
if anyone can help me out with this i would really appreciate it.
Budman
go look for the instalation cd that came with your motherboard and install the drivers.
cgper
9
for some reason my cd doesnt work.
says unknown error.
am i screwed? man this is really frustrating. something so simple should work.
iamaelephant
3,816
What type of internet connection do you have? What type of modem? Have you run the Network Setup Wizard?
biostud
19,746
6,828
you need your motherboard drivers as they contain the LAN driver needed for internet connection, if you can't get the driver CD to work you need to to a friend and download the drivers.
1394 is a firewire connection
biostud
19,746
6,828
if your cable modem supports USB, try using an USB port instead and install the drivers for the modem.
cgper
9
i dl the drivers but i cant open the file.
im sorry for all the noob questions but this is killing me right now.
we transferred it over to my computer and now i dont know what to do with it. i cant open it.
Kremus
55
you need to go to device drivers and install them threw there and point the install to the folder you dl'ed. This will tell the hardware were the drivers are at. just make sure you have them unziped before you try this.
spkack
Guest
Oct 2, 2003
56
If your CD doesn't work, how did you get the operating system installed? If your system recognized the CD when you installed the OS, but isn't recognizing it now, it could be any number of issues from drivers to hardware configuration/failure to BIOS settings.
Assuming you did not change the hardware configuration of your computer (did not remove or unplug anything, and did not add anything), Windows XP (assuming that's what you're using) should recognize any CD during the initial install. If you had the case open, check for disconnected or loose wiring to your CD.
Regarding your network adapter, the Windows install CD does not have many of the network adapter drivers. Since you are only showing a 1394 firewire adapter, it's likely you simply need the drivers installed for your network adapter (and your Internet connection) to work. The real problem you have is how to get the drivers to your hard drive since you don't have a working CD drive. You could try using a friends computer to put the drivers on a flash drive (aka thumb drive) and plug it into a USB port to see if that would work. If your system has a floppy drive, a floppy disk would work as well.
Your system is recoverable, but it may take you some research and time to get there. This will be a very educational learning experience for you. Be patient and you'll figure it out - we've all been there.
stu1811
405
The drivers are probably zipped. You need to extract them with winzip or something on another computer and trasfer them via thumb drive.
