Help I need to know how to overclock
JimmyEatWorld
2,007
To overclock a CPU, you change the Bus speed, and the Clock multiplier.
Depending on what mobo you have, which you hilarilously did not provide, this is done via dip switches, jumpers, or through the bios. Also depending on what mobo you are on, the only thing you might be able to change is your bus speed. For a higher bus speed to work, you might have to change your slot settings (PCI, AGP) or else your slots won't be able to cope with the bus speed. You also might need better ram to achieve this as well. Also depending on your heatsink you might not be able to take it far at all.
bacillus
14,517
<< How do I overclock the Athlon 900 and what can I o/c it to? >>
a little more info like what m/board would be helpful!
BossDog
371
Uhh, if he doesnt even know the very basics, then its not a good idea to start mucking about with the multiplier.
Go read a bit about front side buses, multipliers and voltage settings.
V
Banned
Apr 2, 2001
1,821
Your tbird should at least go up to 1050+. I have seen people with them at 1200mhz.
