- Nov 4, 2000
- 3,795
- 0
- 0
OK, well i went to format and install win98SE the other night, and i formatted the drive, and started installing. when it got to the point where you log in your name, it flashes the screen for a few seconds and then i get a string of blue-screen errors all in a row. i tryed formatting and installing again, same problem. i tryed formatting and installing win98, winME, winXP... all the same problem, i got a blue screen at just about the same point.
up until after the first restart in the windows installation, everything seems to be working fine, which is what baffles me. i also tryed sticking a harddrive in that already had a full install of winXP home on it, and i got a blue screen with that too (but that coulda been cause winXP doesnt like a whole bunch of hardware changing).
heres my rig setup:
Athlon 1.4 266fsb thermoengine cooler w/ delta fan
Epox 8KHA
512 crucial pc2100 DDR
mx400 diamond sound card
netgear 10/100 nic
maxtor 30 gig ata100 7200rpm
geforce2 pro 32mb w/ tv out
yamaha 16x10x40
32x cd-rom (generic)
antec psu
i have tryed removing all unneeded pci cards, and one of the cdrom drives, leaving only the vid card and the yamaha, and ther ewas no difference. i have narrowed it down to being either a hard drive or a motherboard problem, but i dont know which, or even if those are the right things.
i did open up the comp and do a full de-dusting job before i tryed to reinstall, but i dont think i messed anything up
well, please leave your input/ideas... i will try pretty much anything... but dont really have any $$ to buy newstuff right now
LMK what you think everyone, or if you have had this type of thing happen and resolved it.
heres my rig setup:
Epox 8KHA
netgear 10/100 nic
yamaha 16x10x40
antec psu
