HELP! I Need New VGA Cooling for GeForce 2 GTS
jodhas
834
My old GeForce 2 GTS's Fan died out on me...
It's running on my second system and I do not want to replace the Video Card.
The most graphic intensive program I run is Counter Strike... =)
Is there any VGA Heatsink/Fan combo out there for my good 'ol Geforce2?
Of course, I do not want to spend more than $10 to $15...
Thanks...
Jaxidian
2,230
twitter.com
ThermalTake has an old Orb product (not Blue Orb, something like it but newer) that's pretty cheap and good. Personally, I would just take a look at SVC to see what they have that fits.
jodhas
834
Originally posted by: M0NEYSH0T
Can't you buy a Geforce 2 for 15.00?
LOL... You're talking about the Veneral GeForce 2 Pro/GTS here!!! =)
with all the jokes asise, prolly not, I see the ad on the Frys for a new TNT or GForce MX 400 for around $40 (before like $10 rebates) so instead of throwing awya this card, i want to provide adequate cooling and use it.
And Jaxidian, I do remember the Orb stuff,
Does anybody else have any suggestions? How about the new VGA silencer stuffs? do they fit???
cheapgoose
3,877
can't go silent? i have a huge , and i do mean huge heatsink on my gf's geforce 3 ti200 card. works fine.
jodhas
834
I'm sorry, but how is that suppose to help me in anyway???
Apr 27, 2004
54
A cheap solution is the old K6-2/PIII cpu coolers. They actually provide more cooling than the original coolers. Some frag tape or a good thermal epoxy to hold it on. The other option is the Crystal Orb or Blue Orb if you can find it.
SniperMerc
75
Thanks...
http://www.coolerguys.com/840556018063.html
This should do that old Geforce 2 well, also get a fan controller for it, its a noisy little turd at full rpm.
Here's some more optoins to look at. http://www.coolerguys.com/chipsetcooling.html , http://www.svc.com/chipsetcoolers1.html
The little Vantec Iceberq would be a decent setup as well. http://www.svc.com/vanvgaandchi.html
