Help- I need help building an algorithm
Biggerhammer
I'm planning a project- a robot. Right now, the primary sensor will be an ultrasonic rangefinder mounted on a rotating platform. So, with one full revolution, the robot will have 36 measurements telling it how far the nearest obstacle is in that direction.
Now, the fun part. How can I use that to create a map? Some relatievely simple A* work will let me navigate once I have created the map, but going from range measurements to a map is stumping me right now.
Thank you.
(should this be in Highly Technical? Or should I jsut move it to P&M? 😉)
Create a XY plot of the objects detected with the robot at the center of the plot.
Simple High School Trig;
Distance to object * Sin/Cos of rangefinder horizontal angle provides you the relative Y/X coordinate from the finder.
Say the distance is 100 meters at a hortizontal angle of 30 degrees
100 * sin(30) = Y coordinate
100 * cos(30) = X coordinate
Now you have your point ploted relative to your origin.
