!!!!!! Help !!!! I have a Asus P3V4X and need help !!!!!! ????
tHeViPeR1
Ok, I really need somebody to give me the straight dope on what is the fastest cpu I can run on this motherboard.... I was wanting a Plll 866MHz flipchip, is this possible??? Please help, I need an answer as soon as possible!!!
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
17
Yes, 866 is no problem. Grab a BIOS update while you are at it too.
tHeViPeR1
Ok, now I need to know what is the latest bios, I have 1005...Also, what exactly is a flipchip???? I bought a CPU Converter Board, a MSI model MS-6905 Master...
osage
5,686
You can always find the latest official BIOS here ASUS there is a beta version out, but I would not recommend that you try to flash. you have the correct current version.
You can find a lot of good info at the manufacturers web site.
good luck
osage
5,686
Try here for the different chip configs.cpus. Be sure to read all the way down the page for more info.
hope this helps
