HELP!!!
as the description says i have an ABIT KT7 And an AMD Thunderbird. I originally had a 700Mhz P3, Sold it here on anandtech with my golden orb. When to local Comp Show bought a new "silver orb" (GOLDEN ORB DESIGN ONLY SILVER) and it didnt fit on the cpu. so while i was waiting for the money order for the P3 i used the golden orb since it did fit. time came around and i had to pack up the P3 with Golden orb... used older heatsink that fit. Turn Comp on... next thing i know my Super Disk goes crazy. Turn Comp off. Then back on about 5 min later went into BIOS to have a look at TEMP. IT WAS A WOPPING 181 Degrees F (about 83C). I checked to voltage and it is at CPU DEFAULT. NEXT TIME I TURN IT ON I WATCHED THE TEMP CLIMB 3-6 Degrees every SECOND!!! VERY SCARRY!! well before i go crazy i was woundering what you people could sugest to me. thanks
ksherman
ksherman
