HELP! I deleted a system rig. How do i get it back?
sep
2,553
FUUUDDDGGGEEE (only I didn't say fudge)!
Is it possible to retrieve it back?
Can't someone at ANANDTECH add a confirmation box?
allisolm
Administrator
Jan 2, 2001
25,322
4,987
From AnandTech Forums FAQ
"If you are having a problem with the forums, please post them in Forum Issues. You are not guaranteed a response, but staff do periodically check the category. "
Patience, grasshopper.
Jason Clark
Once it's gone it's gone, confirmation I'll look in to.
We do not respond to everything in here, too much to filter through.
sep
2,553
I was upset, because this would be the third time (over my Anandtech life) that I've removed a rig due to browser hiccups. I know I'm not the worlds best developer (and other things), but when I create an action/process that will remove something permanent I want the user to understand that before it takes place.
Thanks for responding,
-JC
Jason Clark
Sep, in reality this was a user error... but you're right their should have been a confirmation box.
Cat13
1,108
I have done the same thing also, more than once. CLicked delete instead of edit, and poof, gone. I like your suggestion for a confirm box.
sep
2,553
It's painful and think a solution should be implemented. How do we get Anandtech to support this and supply progress?
GtPrOjEcTX
10,784
ditto, I just gave up after the 2nd time. No idea about what's in the "My Rigs" for me now.
