Help!! I can't use my plextor PX-W8432T CD-Recorder
zane
28
Last week I got my PX-W8432T from buy.com and installed Adaptec Easy CD Creator V4.02c S10. But I can't burn data CD. Every time, no matter the size of files(20M-630M) or no matter the write speed(2X, 4X or 8X), there is a error message when 99% finished. The error information is:
There is no CD in the CD-Recorder. Easy CD Creator will now attempt to write the table of contents. Please insert the destination CD into the CD-Recorder.
I sure my CDR(they are 12X) and the connection of CDRW are OK. I can burn CD by using CloneCD.
Does anyone know what's wrong with my burner?
Thanks.
bulldawg
It`s probably not the writer, but the Adaptec crap. I tried it when I got the same writer, and had nothing but problems. Now I use Nero and Clone CD with no problems.
Nero
zane
28
I try nero v5. It works. CloneCd works too. I don't know what's wrong with the adaptec easy CD 4.02, which comes with the plextor writer.
Thanks.
AngelOfDeath
1,203
Yes it's Adaptec. I had the exact same problem..Then I moved to Nero, and haven't had a problem ever since :).
AoD ;)
