My g/f gave her old PC to her brother when she got a new one. It's an P3-700 on an Abit BH6 mono with 386MB RAM and a puny 6.4GB HD, but since he's never had a PC before and is only going to be on MySpace and stuff, it's enough for his needs.
Some friend of his reinstalled WinXP Home SP2 over the existing install (Why? I have no effing idea.) and because he didn't have the right key and was too lazy to look it up, used a key gen to install and then cracked the activation. Well, I get the call that bro is locked out of the PC because it's demanded to be activated before it'll let him log in and when the Activation window comes up, it says that it's already activated. Lovely Catch-22.
I've got the PC and for some reason, even after fixing the boot order, it won't boot off the CD drive. It still has a floppy and I tried to use a Win98 boot disk to load it and it wouldn't run the WinXP install - either saying it won't run in DOS or giving an error that there's no place for a swap file. By logging into a Safe Mode command prompt, I was finally able to get a Repair install going but after that, it still had the same Activation problem.
I want to format the hard drive and then install a legal copy of WinXP Home that I've got. Nothing flashy, just a clean install. HTF can I do that when everything is geared to booting off the CD? I can't make a WinXP floppy set because my PC doesn't have a floppy drive. The other PC can't boot off a USB key. How can I make this happen?
TIA!
[edited to prevent assumptions]
TIA!
