Help I am new need help!!!!!
md300
56
ok i bought a home net working kit with two cards hub and cables ect after setting up cards in both computers then set files up like adapters networking ect and connect them computers together what do i do then i have enable the file and printer sharning also how do i play games agaist each other the two computers thanks joe as detailed as possible thanks
igiveup
1,066
WOW. Its called a period. My eyes are havin trouble breaking that thing apart....
Ok, lets see. What operating systems are you running? You will more than likely need to set up each computer on their own IP address. Note that unless you are going to run Internet Connection Sharing you won't be able to access the internet from both computers with this setup (can't play games online at the same time. Playing against each other will still work fine). Tell us what you are working with and we will see if we can help. Plus, read the manual that came with your kit and follow the instructions. They usually try to make the manuals easy to understand because they know it will be your first time if you use one of these kits.
See? Isn't punctuation so much nicer? :D
