HELP: I am going nuts!!! Cable Length, is it the issue?
CURLYnoodle
123
Okay, this makes no sense to me whatsoever... so can someone please explain to me what the issue is!? I have a HP laptop with the Realtek 8139 chipset. I was using a 50ft cat5e cable with it when i wanted to get the best transfer between my computers instead of wireless. Then one day it stopped working, so i figured it was the port or the cable. I tried a 6 ft cable and it works fine, so i determined it had to be the cable. I tried another 50ft cat5e and it doesnt work and then i tried a 50ft cat6 and it doesnt work either. could someone PLEASE explain to me why this isnt working? was there some driver update that affected this, is there some setting i can change? i know those sound like dumb questions, but i am perplexed...
Thanks in advance,
dan :confused:
ScottMac
Moderator<br>Networking<br>Elite member
Mar 19, 2001
5,471
Were those cables hand-made (you or whoever) or purchased, commercial-grade stuff?
If you hand-made them, did you follow the EIA/TIA spec?
If not, that's likely to be your problem.
FWIW
Scott
spidey07
65,469
Originally posted by: CURLYnoodle
nope, all store bought.
something is really not right then if they are store bought cables.
BUT - it does happen that pre-made cables are bad. Or, the NIC could be bad. Its rare, but it does happen.
CURLYnoodle
123
BUT 3 DIFFERENT 50ft cables? Doesnt that seem odd? and i know that 2 of them worked fine before! any other ideas?
dan :disgust:
spidey07
65,469
dan :disgust:
If you've swapped 3 cables and those cables have been verified good (either by certifying them or using in a different installation) then it must be the network card.
My angle is that most all network problems are from the physical layer (cable). Make sure they are indeed cat5 cables.
n0cmonkey
42,936
Can you test the 50ft cables between two other systems?
I personally wouldn't expect much from a realtek 8139 card. :p
CURLYnoodle
123
yeah, i tested them with my desktop system just now and it works fine. The only reason why i am confused is the network card shouldnt see the difference between a 6 foot cable and a 50ft cable... ya know? its very very bizarre....
spidey07
65,469
If its bad it will "see" a difference.
