HELP!!!! HSDRAM 150 Mhz or Mushking High Perf Rev1.5 PC133 CAS2??????????
RabeaticSquirrel
365
Ok so the HSDRAM can hit 150 at CAS 2-3-2. But the High Perf Rev1.5 PC133 can hit around 146 (according to anandtech) at CAS 2-2-2. For the bucks it seems the High Perf would be a better pick, but I'm looking for the performance. I understand the differnece in the CAS latency 2-3-3 vs 2-2-2 may only provide 1-2% increase in performance. But would the 150 be that much more stable. It also seems (and I'm trying to think logically here) I were to get the High Perf, I'd be OC'ing to hit 146, which would generate more heat, and strain, and may eventually lead to stability issues. On the other testicle, we've got the 150 which would have to be "underclocked" so to speak, should my PIII not make the 150 FSB mark. That's just my load on the subject, any suggestions/comments??????
Zipperhead
1,277
I have both the rev2 and pc-150.Both are excellent.Slight edge in
performance go's to the rev2,pc 150 will obtain higher fsb's.
Zip
