The 3.5 in bays can be used by removing one stud and use 2 mounting screws. Not pretty, but it functions. See the link pictures.
For my SSD in a different case I just used 2 sided tape and placed it were it would get some cooling.
I think this is where I went wrong - I assume(d) that tool-less meant that the drive could be mounted without tools.
The caddy removes "tool-less-ly", maybe that's what's meant.
Removing the stud and then screwing one from side and bottom is what I ended up doing.
