HELP How to lower bus speeds KT7a R Duron650@1000
rarebear
450
I just ran Sisoft Sandra and it is telling my
AGP 88MHz
PCI 44MHz
ISA 11MHz
DMA 6MHZ
Buses are to high
In the softmenu I did not see how to lower the bus speeds and I thought I read it will take care of it self pretty much..
Hope I don't need to lower the FSB
Duron 650 @ 100 (7x133)
Thanks
Technonut
4,041
Sandra is incorrect, and does not support the KT133A chipset yet, so you are not out of spec. They say so on their website.
As for setting up your KT7A RAID, what do you need to know? Looks like you already have it at a 133 FSB. As for other issues and tips, try The KT7 FAQ Site when they are back up. (Seems someone hacked the site) If you have a specific question, LMK, and I will try to answer you.
