help: How to check a persons "HEAT"
<< so what is heat?
and...for rating...and 1 the better end or 10?
there are no number ratings in heatware. its just positive, negative, or neutral. i think the 1-10 thing u r talking about is user ratings.. which actually mean nothing at all.
<< i was refering the 1-10 user rating on the anandtech user rating site... >>
it means nothing. if the user has a high user rating... that prolly means he doesn't come to Off Topic forums... hehhee 😛
hang around here long enough and ur ratings will surely be raped.
BTW... not all ppl have their rating enabled. if u go to edit ur profile, u can disable and enable that option.
<< so is your "heat" is considered the most important thing in doing deals/trades here right? >>
Yes. Heat allows other to make comments about your trade.
yeah heat is pretty important. sometimes ppl's heatware id is different from their AT name... so be careful with that.
