Do NOT use a hub to extend beyond the barrier. A hub will not increase ethernet segment length. Only switches, which use per-port buffering, can accomplish that feat. >>
I want to clarify that last point. There are several distinct cases, and need to be addressed separately.
10 Base T. Conservatively, 3 repeaters can be used. If your office is using a switch, repeaters could extend the distance an additional 300 Meters. On the other hand, 10 Mb fiber is inexpensive and can go 2 Km.
100 Base T from a switch. A repeater can be used to extend the distance, and each can be up to 100 meters. The penalty is that because of the hub, only half duplex operation will be supported.
100 Base T from a hub. A class 2 repeater/hub is allowed to interconnect to one other Class 2 hub with a 5 meter cable. No Idea if the home stuff if class 1 or 2. In other words, a second repeater does not buy much distance.
Switches will allow the extension in all cases.
Summarize: Switch always, hub @10mb "always", hub @ 100Mb, caution.
By the way, its 100 Meters for twisted pair, 185 Meters for 10 Base 2, 500 meters for 10 Base 5, and 50 meters for a transceiver cable.
We just assume that you are talking 10BaseT or 100 BaseT.
Regards;
Doug
