Hey everybody...I'm not a moron, I swear, I was just asleep.
I just installed the TDK 24x10x40 VeloCD (THANK YOU LITE-ON!!!!), and before going to sleep I put the case back on...this morning, the drive didn't work, and I found I had accidentally unplugged it from the PSU when I put the case on...
Mind you, I just woke up to go to work.
So I plug it back in....and my entire system shuts down...In fact, I couldn't get it to turn back on until I turned the PSU off and unplugged it. Everything seems to be working fine. Should I consider myself in the clear? Is there anything that I could have damaged that wouldn't be apparent?
I have a 350W Enermax Whisper. Is this just a security feature in the PSU that shuts the computer down when there is an overlaod?
Thanks,
- idcandy
Thanks,
- idcandy
