Help? how 2 turn on AT power supply?
KLUDE
38
I got a really old 230W AT power supply with the P8 & P9 plugs. Even with the on/off switch, it only works when connected to the MB. How do i get it to work w/o the MB. I was only able to find instruction on how to get the ATX power supply to work. Nothing on the AT power supply. Please HELP! Thanks
Carrot44
<< Fog mode on >>
There is the power good signal that tells the MB that all is good maybe the MB needs to send something back?
Also it needs a load on it of some sort try a HD
Ken
MajinWade
334
I think something is wrong with it. Should work without the MB, at least the 2 i've used have.
KLUDE
38
Thanks guys, I connected it to the CD-ROM and it works GREAT! I guess the load of 3 fans is not good enough to turn on the power supply. Thanks a bunch guys.
Floydian
506
The old AT powersupplies just need a resistence on the 5 volt line, so a resistor between the +5v and the 5v ground line would work as well.
