When the Benchmark quits after the "pixel fill test 2" (the test after the "nature scene"), I get the following message in a small window...
3D Mark could not initialize your 3D accelerator. Try to downgrade your display settings. DIRECTX error Message: setFullscreen-craeting the device failed: EOUTOFMEMORY
HELP!!! What could it be???
Vcache in the system.ini file was "blank" and then I changed Vcache to 128000 min and 128000 max... Didn't help... BTW, what should these be set to when one has 512 Megs of RAM???
More info on the problem...
