Help hooking PC to TV
kevinb44
33
I am trying to hook up my Mits HD ready to a PC using it's HD input(5 RCA's. When I boot up I get nothing. Any idea what I am doing wrong? I am using a PCI Voodoo 3 2000 card and a VGA to 5 BNC with RCA adapters. Thanks.
Workin'
5,309
You should check your TV's documentation or consult the manufacturer to see if it tells you how/if this will work. I'm not entirely sure that the VGA signal is compatible with the HD input even if you use an adapter cable such as yours. All the HDTV's I've seen that support use as a computer display have a 15-pin VGA D-sub connector.
kevinb44
33
I know my TV can do it. You need to use a program called Powerstrip to adjust the picture. Can anyone help me set up Powerstrip? Thanks.
