help... help...: WRT54GL connector
nweaver
6,813
does the WRT support POE? iirc, all the rootenna's I've worked on don't offer power inputs, but rely on POE. You may be better served going with a product designed for this? We use Tranzios and Smartbridges equipment in Rootenna's all the time.
khurios2000
7,531
yes, WRT54GL support power over ethernet.
so rootenna is not the best option?
any suggestions?
nweaver
6,813
what are you trying to do?
So you can power up a WRT with a POE line, and not have the ac adapter plugged in?
