HELP! HELP! Unlocking Mistake!
Dhanu
Damn!!! When I tried unlocking the CPU, I accidently connected two bridges with the pencil. How do I remove the connection? Would an eraser work? If so, how can I ensure that I have done this correctly?
Damn, this harder than I thought...
Dhanu...
gygheyzeus
1,084
eraser. i know, when i first got mine im like, oh, no problem.... but damn those things are close together in real life. just takes a steady hand...
if you mess up... erase very carefully over it...
PaNsyBoy8
1,446
rubbing alcohol takes away everything, well almost but ever since i was a kid, to remove pencil, i've always used an eraser. hehe =) good luck
MplsBob
340
John, above, almost had it right with
(1) Eraser
(2) Rubbing alcohol
Actually, it should have been,
(1) Eraser
(2) Very good bourbon
Sip the bourbon slowly over quite a period of time to settle the nerves, being very careful to ingest enough bourbon, but not too much. Sometimes this step may need to be repeated over several days in order to get your preparation just right.
Then use the eraser.
Just kidding, of course!
Moonbender
1,046
Does anyone know what happens when you try to boot up a CPU with connected bridges? Thermonuclear explosion?
mastertech01
Moderator Emeritus Elite Member
Nov 13, 1999
11,875
282
May more like a Neutron bomb.. destroys all life but leaves the core hardware intact..
