HELP, HELP, HELP!!!! MOHAA Spearhead question
SeminoleMarine
211
I know I am illiterate when it comes to these things, but I still need help.
I was playing MOHAA Spearhead and the screen went to 2/3 its original size. Not the monitor, just the game screen. I quit out and restarted the game and now the screen image is about 1/4 the size. I have tried everything (that I can think of) to fix it, I even uninstalled the game and reinstalled it, but nothing seems to work. Any help is desperately needed. I know the game is old and there are better ones out there, but I love playing this game and so does my son. Thanks in advance for any help.
Calculator83
Banned
Nov 26, 2007
890
MM,, check your video settings and make sure you're set to ,, Scale image to fit screen.
A little more info could help
Graphics card:
Monitor:
SeminoleMarine
211
I will try that and see. It seems to be only the spearhead game screen that shrinks. My computor is fine and I play Allied Assault as well and it is fine.
Graphics card: Nvidia GeForce 8400 GS
Monitor: NEC LCD22wv
BFG10K
22,709
3,001
It sounds like you have 1:1 scaling on your LCD but the game is running at less than native res.
Calculator83
Banned
Nov 26, 2007
890
Yup, Or somehow That game is specifically Requesting it from your graphics card. I've been stuck with an x1900xtx for past 2 years : (, So i don't know how to navigate the menu.
BFG10K you're up!
SeminoleMarine
211
Thanks for the help guys. I have tried everything to no avail. I guess I am going to have to uninstall the game and load it on another machine and see if I get the same problem. At that point I will dig deeper if necessary.
