Help! Help! Help! How to remove liquid paper (white-out) from clothing?
Howard
47,982
11
Dark blue, slightly rough fabric, a round spot of white-out (on both sides), 97% cotton 3% polyurethane.
How do I remove it??? If I can't then my hat is pretty much wasted...
Beau
17,730
www.beauscott.com
Stain Removal Tips
Whiteout (Liquid Paper) (Liquid Correction Fluid)
Purchase some Spray & Wipe from your supermarket, and use concentrated on the stain. Most Spray & Wipe formula?s contain a solvent which will dissolve the liquid paper. OR Try a little xylene, or toluene on the stain, with some good absorbent paper or old cloth behind it. Then use some dishwash liquid or a good quality laundry liquid to wash out the solvent. Always test an inconspicuous piece of material before proceeding.
