OK i have a 800mhz AMD Thunderbird
I have a Gygabyte GA-7ZM Mobo
wich doesv't have a Multiplier adjuster
so i have to Alter the bridges on the chip
Have any of you had to do this ?????????
and how the hell can i cut the Bridges if need could i use a regular cutting razor with a new blade and get a magnifine glass and do it that way ????????????
Thank you
Thank you
