HELP HELP HELP HELP HELP!!!!!!!!!!!!!
dguy6789
8,558
Hello, I am running Win64.
I installed the following desktop theme:
http://en.crystalxp.net/bricopack-longhorn-inspirat.php
All went accordingly and then I restarted. When the pc loaded up, all that was on screen was the background image. No start menu, no nothing. So I figured no biggy, I pushed ctrl alt delete and uninstalled the program. I did that and restarted the pc.
I now have my regular background image, but that is it. There is no start menu. I went into the Windows folder and double clicked on Explorer only for a message to come up saying "C:\WINDOWS\explorer.exe is not a valid Win32 application"
WTF???!!!
I tried to run system restore, but it gets to the part that says preparing to restore, and just hangs there indefinitely.
Please HELP ASAP!!!!!!!
dguy6789
8,558
Ok nevermind guys. I tried reinstalling the theme to see if I may have done something wrong, when I got a message from Windows to insert the X64 cd to fix some missing files. I popped in the x64 cd and BOOM my desktop came back. I never thought I would say this, but MS is pretty ok.
