ZL1
Hi
guys I need help bad, my CPU is hitting 60deg C at stock speed
its an AMD 1.33 Athlon, I just changed my mobo and it hangs and after reboot mobo says check out hardware monitor which shows 60C temp for the CPU
now it didnt use to do this on the old mobo (ECS K7S5A) now why does it do it on the new one ? (Asus A7A266) Ive heard of a bug asus had with cpu temps being incorrect, could it be that ??
please help
Thank you
Dan
please help
Thank you
Dan
