Hi All,
Back again to ask more questions. Now I'm having a problem installing a CoolerMaster Hyper N520 heatsink onto my Supermicro dual Xeon Nehalem X8RDAi-O motherboard. The Motherboard already has a backplate installed, and while the holes for the 1366 heatsink correctly fit the motherboard, they won't all screw in simultaneously. I've tried using quite a bit of force with no luck.
The Coolermaster heatsink is supposed to come with it's own backplate, but there doesn't seem to be a way to install the default one. Furthermore, the coolermaster backplate seems to go directly over some important connections on the back of the motherboard, so I don't know if that would be the best way to install the system either.
Any ideas? Thanks for your help,
~Lyuokdea
~Lyuokdea
