Hi, I've got an Abit KR7A-133 mobo and a AthlonXP 1900+ (1.60 GHz) and I'm using a Thermalright SK-6 HSF with a 6000 rpm Delta fan. I'm also using Arctic Silver 1 thermal grease. Now my idle temps are between 46C - 48C (114F and 118F) and my full load temps are between 49C - 52C (120F - 126F). When I had my Iwill KA266-R mobo my idle temp was 39C - 42C. I don't understand why their is about 12 degrees difference in the two mobo's. Is the Via KT266A chipset that much hotter than the ALI MAGiK chipset or is there something wrong? The system temp seems to be around the same for both boards around 31C - 33C (87F - 91F). I know my CPU is running a little hot and I don't like it but is it in any danger? I've read the cpu temp limit at AMD and they say it will go up to 90C (194F) but is mine in any danger I wonder and is there something I can do that is passive or even by software (other than Waterfall) that can cool it? All my games and 3D apps are running fine but when there is that much of a difference from my Iwill (despite the fact that the board is crap!), I get a little concerned. I've taken the HSF off and clean it and the cpu and reapplied thermal grease....I don't know what else to do.
Does anyone else have this setup? Is this a normal temp? That's what I really want to know and if so...what else do I need...but my main concern is....is this a normal CPU temp for this board?
Thanx for the help in advance!!
