- Nov 25, 2011
- 5
- 0
- 0
Hi everyone,
Having some issues with a Sapphire 11188-05-50G HD6950 Graphics Card (2GB, GDDR5) - Dirt 3 edition
I had a few issues installing - I uninstalled old drivers, shut down, put in new card, restarted, installed new drivers - and the screen went black.
This appeared to be resolved when I installed the new drivers from the manufacturer's website in safe mode.
I played Skyrim happily for 2 hours - and then then monitor went off, and the system froze. Had to do a hard reset.
Now, the computer starts ok, (mostly - occasionally the monitor won't power up and I have to reset again.) But every time I try to run Skyrim, the game gets to the Load Game menu and the same thing happens. Monitor goes off, system freezes.
I have a 500w power supply, which is what the card says it needs
I've plugged it in using 1 molex to 6 pin that was powering the previous card, and from another molex that was free that wasn't being used before. Are there specific molex's I should run the second 6 pin from?
My system specs are below - any help gratefully received.
Operating System
MS Windows XP Professional 32-bit SP3
CPU
Intel Core 2 Duo E6550 @ 2.33GHz 45 °C
Conroe 65nm Technology
RAM
4.00 GB Dual-Channel DDR2 @ 400MHz (5-6-6-31)
Motherboard
ASUSTeK Computer INC. P5N-E SLI (Socket 775) 40 °C
Graphics
Hard Drives
488GB SAMSUNG SAMSUNG HD501LJ (ATA) 30 °C
Optical Drives
Virtual CDROM 0CF320FF USB Device
ATAPI DVD A DH20A4P
POLMT 349UB05 SCSI CdRom Device
Generic DVD-ROM SCSI CdRom Device
Audio
Realtek High Definition Audio
Operating System
CPU
RAM
Motherboard
Graphics
Hard Drives
Optical Drives
ATAPI DVD A DH20A4P
Audio
 Facebook
Facebook Twitter
Twitter
