Help!! having problems with Asus P4B533
phamtastik
I have a Asus P4b533, everything is stock no overclock. I installed Win XP and it installed fine. but when im in there it crashes.. pretty soon
im running on stock heatsink an fan. tested multiple RAMs but that doesn't seem to be the problem
Intel P4 1.8Ghz
FSB = 100mhz
CPU temp is about 40 C is that high?
80Gic WD "special edition" HD
512 Crucial Ram DDR PC2700
any help is much appreciated.
I am glad to see you found out the problem.Never would have figured that your PCI network card was causing you to crash.
I figured it out finally. it was a PCI card that I was using. A netgear 10/100 base Netowork Card to be exact. I tried other netgears and I have the same problem. I am yet to try a different brand NIC
THanks for the help
