I have 2 maxtor 160 hdd with 8 mg cache...both made in May 2003
I have been trying to get a stable install of winxp pro with sp1 slipstremed installed....I have used maxblast software to format and partition and then try to install winxp sometimes the install works but then crashes when I try to install winxp updates..other times I get failures during install
My setup:
P4 2.4 133 fsb I am not overclocking during install
512 ram
IT7 Max2 rev2 mobo
the hdd is on the hpt ide 3 channel no other drives are hooked up and I am using latest bios on my mobo and hpt 374 drivers..both support large hdd over 137 gb
After several tries last night I did a full data wipe off one of the drives to clean off any residual crap took like 4 hrs ...the nreinstalled winxp pro and the updates off MS website get crashing and rebooting the system
My setup:
512 ram
IT7 Max2 rev2 mobo
