- Oct 9, 1999
- 94
- 0
- 0
Ok, I just got myself a new IBM 45Gb hard drive from the new ATA-100 line, the 75Gxp. Well, I stuck it in, fdisk'ed it and make 3 partitions, 5, 10, and 30. I set the primary dos partition (the 5 Gb) as active and rebooted. I then formated all three partitions and rebooted yet again. Next, i proceeded to install Windows 98 Se. After the final reboot it asks me for my 98 cd which is still in the drive. It can't detect any cd-rom's once it has booted into windows!! The Via Busmaster IDE controller driver is installed, and seems to work. But, the Primary and secondary IDE controller have the yellow exclamation next to them. When i go to the performance tab under system properties it says the drives are in Ms-Dos compatibility mode. Ok, so I figure that i might as well install the newest 4 in 1 drivers from Via (4.23) but they did not work.
So, back to step 1. I booted off a boot disk, used a progrm from IBM (ZAP)to write all zero's to the master boot record. I then went into fdisk and made my 3 partitions again. rebooted and fomatted them. I used the boot disk to start up (the boot disk detects my cd drives just fine) and copied the windows 98 directory to my c drive under a new folder. I then ran setup again, and after the last reboot when it could not find the CD, i pointed it to the copy I made on my hard drive. It foudn all the fiels it needed, but the 2 ide channels were still not working and had the exclamation point. In windows explorer, it shows my 3 partitions, but no cd drives. Help!! Any more info you need, I can tell you, so please ask if you think you can help.
System Config
Athlon 850
KA7-100
IBM 45 Gb ata 100 hard drive (set to ata 66 using a utility) and connecte to IDE 1 (ata 66 port)
2 cdroms attached to IDE 2
Also, After giving up on 98, i tried installing windows 2000 Proffesional (which I am on now) and it worked just fine!! Very odd, but I need windows 98 to work! Also, all I did was install a new hard drive, my system worked just fine when i had my old hard drive installed (IBM 34 GB). Thanks in advance for any replys.
System Config
Athlon 850
KA7-100
