madhandles
I have two partitions on my harddrive and I was moving some data from one partition to another but it would stop in the middle of moving the data because it couldn't read it. So I suspected hard drive corruption. Soon after, a blue screen came up (I'm running Windows XP) and told me there was a fatal error. I restarted my computer and it wouldn't go past the windows xp splash screen and boot into windows. I recovered some of my important files using a boot disk and ran chkdsk. I tryed installing windows again but it would give me an error saying couldnt create c:\windows or some other folder. I then deleted one of my two partitions that has windows installed on it, created a partition again, formatted it using ntfs file system, and then attempted to install windows again. However, the same error occurred. Is there any program out there that I can run to possibly fix the harddrive problems? I think the harddrive got corrupted by me accidentely cutting off the power to the computer while it was on.
