problem is that when i shut down my pc at night and turn on again in morning, my hard drive gets corrupted. windows will boot to desktop, but become unable to open the first app i try, heavy hdd access ensues, pc reboots, scandisk fixes errors, everything then works fine. sometimes i leave on for a few days, and when i do
reboot while computer already on, everything is fine. problem only seems to happens from a cold boot.
the odd thing is that i rma'd the hdd, reinstalled fresh on the new drive and started getting same error. so i'm not sure if there's just been a bad batch of hdd, or something in my system is causing the problem.
i ran memtest overnight and got 0 errors. i switched out ide cable, but happened again. how can i figure out what the problem is? can it be some software issue? what else should i test, before rma for another hdd
system: win xp, a64 3200+, dfi nf3 250gb mobo, antec 430true, wd 120gb hdd, nec 3500, 2x256mb crucial ram. everything always run at stock speed.
