HELP! Grub booting problem
Netopia
4
Hey Guys,
I just used Ghost to upgrade my Fedora install from a 80GB drive to a newer/faster 120GB drive. The Ghosting seemed to go ok, except for one thing... now when I go to boot, I just get the word "grub" and nothing more. The fs seems ok and I can boot from a Fedora floppy into the system just fine and everything appears to work. I checked the partition and it is set as active, so that's not the problem either.
Any ideas? Is there a way to "reinitialize" the boot partition?
Thanks in advance... I'm off to google for more info.
Joe
Netopia
4
WOOHOO!!! Fixed it an all is fine.
In case anyone else needs the fix, I'm going to enter some keywords here so that the search function can find it later:
just grub upgrade can't boot linux
The fix was to boot from the floppy and then once in the system go to a command prompt and type:
"grub-install /dev/hda"
Did that and now all is SWELL!
Joe
