My rig:
I5 2500k; 8 gig of ddr3 @1333; Z68 mobo GA-Z68XP-UD3 ;M4 64gig SSD (two other hard drives for games and storage); PC power and cooling PSU; 24 Asus Monitor; Win 7.
Latest AMD driver and F9 bios for mobo (a roll back that is more stable).
History of issue:
I had a 7870 xt and around the time Bf4 came out I have been having issues with the computer recognizing that I have a gpu. I have RMA in for the 7870xt. I used a gts 250 to hold me over. With the gts 250 the system is 100% stable and all things run fine. I got a hold of a 7970 and it run just fine for all things but one.
Problem:
After I power my computer off for the night, the computer will not recognize the 7970 unless I do a hard reset. Then all things run fine, including short sleep or hyphenation modes. The problem was worse with the 7870 xt but it is nonexistent with gts 250. In fact, the gts 250 will show that is is being booted up before windows comes on.
Other symptom, my settings are not always saved from when I turn off the computer and turn it on.
What could be causing this?
History of issue:
Problem:
